Activity Forums Adobe After Effects Broadcast safe RED ??? Should I worry ?
  • Broadcast safe RED ??? Should I worry ?
    Posted by Jennifer White on November 19, 2005 at 1:24 am
    Hi ,
    I’m working on a piece with lot’s of red all throughout (in NTSC). What are the safest values to work within ? Any tips, suggestions or things to watch out would be highly appreciated. Thanks very much,
    Jen
    PS
    At the moment my two main red values I
    Aharon Rabinowitz replied 20 years, 10 months ago 3 Members · 3 Replies
  • Devin Uzan
    November 19, 2005 at 6:43 am
    You can always adjust afterwards. Do your work then view on a few different TV’s–calibrated and not. Adjust accordingly.
    But yes red is generally problematic at high saturations.
  • Jennifer White
    November 19, 2005 at 7:14 pm
    Thanks Zanian,
    So what are the “high saturations” values ? I don’t have a broadcast monitor, but does “broadcast safe color” filter do anything ? Also, in case like this should I use waveform monitor or vectorscope?
    Jen
  • Aharon Rabinowitz
    November 20, 2005 at 10:31 pm
    Here’s a trick I’ve used successfully in controling safe colors, which may help here…
    At the top level of you final comp, create 2 adjustment layers.
    #1 -On the 2nd layer (not the top one), applya alevels effect and then apply the following settings:
    In Black: 16
    In White: 235
    #2 – On another adjustment layer on top of that, use the same effect with the following settings:
    Out Black: 16
    Out White: 235
    You can skip #1 if it looks better – but #2 is crucial to get rid of hot colors. The point of using this is to get rid of hot colors – you will see a difference on the computer screen- things get a bit duller, but you will barely see a difference on the TV, and the untrained eye will not notice a thing.
    It’s not ideal, but it does work.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
