Activity Forums Adobe Premiere Pro Broadcast-safe questions
  • Broadcast-safe questions
    Posted by Stefan Johansson on December 14, 2005 at 11:01 pm
    Ok, here’s a few questions about the broadcast-safe filter.
    How important is it to use this? I always adjust the white, black and
    all additional graphics to “look good” levels anyway. I mean, if the finished video
    looks good (no color bleeding etc) on my TV, is there any reason for applying the filter?
    And IF I ever would produce something to be broadcasted by a TV-station, don’t they
    have capabilities of doing their own brodcast-safe on all material before it’s being televised anyway?
    I also read somewhere that there is no standard for broadcast-safe. Is this true?
    //Stefan
    Craig Howard replied 20 years, 9 months ago 2 Members · 3 Replies
  • Craig Howard
    December 15, 2005 at 12:38 am
    You do not need to use it unless you ever do broadcast something – the Station will require it to be “Safe” and technically correct in other areas as well eg audio levels. They wont do it for you.
  • Stefan Johansson
    December 16, 2005 at 12:25 am
    So if I want to make my material broadcast-safe; what program should I use? Is the filter found in Premiere Pro a good one?
    Magic Bullet’s broadcast safe, maybe? The manual only speaks of making broadcast safe for NTSC though.
    PAL here.
  • Craig Howard
    December 19, 2005 at 10:04 pm
    Use the PremPro one. I do not think this is a very big issue and the process is only limiting the Chroma to a broadcast safe level.
    I never bother with it and I broadcast a lot from DV / PremPro.
