Activity › Forums › Adobe After Effects › broadcast safe problem-
  • broadcast safe problem-
    Posted by Misterkyo on February 25, 2006 at 11:18 pm
    Okay, following the tutorial for broadcast safe.
    One problem: My levels filter has switched to a percentage (0-100% instead of 0-255) all of a sudden (which seems odd). Is there a way to switch it back? I couldn’t find it under the levels filter options or the preferences.
    Alternatively, what is the equivalent of 16 and 235 in a percentage?
    Misterkyo replied 20 years, 7 months ago 2 Members · 2 Replies
  • Aharon Rabinowitz
    February 26, 2006 at 12:17 am
    click on your info pallate a few times, every time you click, it changes the way in which numbers are displayed – it cycles through the different methods of display and eventually it goes back to 0-255. Or you could just click on the flyout menu on the info pallate and reveal the options, and choose the right one (i think it will be deafult method or something like that).
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Misterkyo
    February 26, 2006 at 12:38 am
    I got it, I think it may have switched to that because i just started using 32bit mode today.
    Thanks very much for the help, and thanks very much for your podcast about broadcast safe. 🙂
    MisterKyo
