Activity Forums Apple Final Cut Pro Legacy Broadcast safe not working on render
  • Broadcast safe not working on render
    Posted by Penelope Wylder on August 24, 2009 at 2:56 pm
    I know this has been covered in other posts, but I am looking for the best solution to my problem and would really like to know what other people use as a fail-safe method…
    I am applying the Broadcast Safe Filter (extremely conservative) and a Levels filter to DV PAL footage. This works fine until I render and then the levels exceed 100 IRE. Is there something I am not doing? Is there a render setting that I need to change?
    Some people recommend the RGB limit as an alternative but I have never used this before, and so if there are any problems with this, I’d like to know about it before I use it to make this program safe.
    Any advice greatly appreciated.
    Editor / Colorist
    http://www.petaridley.com
    Ernie Santella replied 17 years ago 2 Members · 1 Reply
  • Ernie Santella
    August 24, 2009 at 4:08 pm
    It’s been posted before that a fix to that issue is to export the entire timeline out as a single file and then re-import, then export.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
