Activity Forums Apple Final Cut Pro Legacy Broadcast Safe Levels
  • Broadcast Safe Levels
    Posted by Greg Pruitt on January 3, 2008 at 4:54 pm
    I just finished editing and color correcting a project on my Mac Pro using DVCPro HD 1080i60 as my sequence settings. All the shots show that they are broadcast legal after rendering (in some cases I used the broadcast safe filter but in most I used the 3 way CC). In order for me to lay the project off to tape I had to make a master QT from the project sequence and take it to another Mac that has the HD deck hooked to it (I exported using “Current settings”).
    Here’s the issue…
    Whenever I bring the Quicktime into a sequence almost all of the white levels are now illegal. Even if I import the master QT into the same project the levels show up illegal. Any suggestions?
    Greg Pruitt replied 18 years, 7 months ago 2 Members · 4 Replies
  • Chris Borjis
    January 3, 2008 at 5:16 pm
    The render settings for the sequence, are they set for 8-bit or 32-bit high precision?
    if its set for 32 bit, make it 8 bit.
    what version of fcp are you using?
  • Greg Pruitt
    January 3, 2008 at 5:47 pm
    I have the latest version of FCP. I did change the render settings to be high precision YUV. I’ll try the 8-bit and see if that works.
  • Chris Borjis
    January 3, 2008 at 10:42 pm
    High precision YUV causes problems and actually doesn’t improve anything really.
    I bet your ok after reverting to 8-bit.
  • Greg Pruitt
    January 7, 2008 at 1:35 pm
    Changing the timeline to render 8-bit didn’t work. Still have the same problem. Any more ideas/suggestions? I’m stuck!
