Activity Forums DaVinci Resolve Broadcast safe in Resolve..
  • Broadcast safe in Resolve..
    Posted by John Whitcomb on December 12, 2010 at 5:22 am
    In Color, you can hit the “Broadcast safe” button, which is great.
    Is Resolve setup to render in broadcast safe out of the box? Where is this setting? (cant find it in the manual)
    Stig Olsen replied 14 years, 4 months ago 3 Members · 2 Replies
  • Darin Wooldridge
    December 12, 2010 at 7:06 am
    A couple ways to handle this.
    1st is on the config page.
    This automatically scales your full range 0-1023 video to hd 64-940 legal for layoff and render. Beware the internal scopes do not represent the true output in this mode. You must run through and external scope to see the results of using this function. You also must grade with it on or off you cannot change it without trimming your list.. As you will see by looking at your display the output changes when you toggle this function.
    2nd is work in full range and build a lut to limit at 64_94.
    Darin Wooldridge
    Colorist / Technical Strategist
    818-653-3918-cell
    dwooldridge@mac.com
    check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=….
  • Stig Olsen
    May 15, 2012 at 12:57 pm
    Do you work normal range for TV delivery?
    I have always done that myself, but figuring out today when moving my final file into an Flame with a lot of other commercials (from other production companies) that they were all full range except my file. Adstream let you deliver with true black for TV.
