Activity › Forums › Apple Final Cut Pro Legacy › Broadcast Safe effect
Posted by Scott Witthaus on October 5, 2005 at 8:57 pmHello all –
has anyone used the Broadcast Safe effect, and how effective is it? Are the default setting sufficient? I see that it does the luma and chroma clips…what about black levels. Thanks in advance.
Scott Witthaus
Senior Editor/Post Production Supervisor
Greybox, LLC
Richmond, VA USA
http://www.greybox.ccKurt Hennrich replied 20 years, 11 months ago 4 Members · 5 Replies -
Alan Okey
October 5, 2005 at 9:10 pmThe broadcast safe filter is a quick and dirty way of making sure that peak luma and chroma is within broadcast legal tolerances, but it’s not an ideal solution in terms of quality. The filter clips excess luma and chroma signals, but it’s not necessarily subtle or aesthetically appealing. I think it’s best to perform color correction mannually on a per-shot basis in order to achieve the best possible result. Like most things, it takes more time, but it’s worth it.
Walter Biscardi
October 5, 2005 at 9:18 pmI use the 3 Way Color Corrector for the primary correction and then throw the Broadcast Safe filter on as an extra precaution for any spikes that might appear in the scene.
Note that this filter does nothing for the blacks. I use the Levels filter to protect the blacks.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
G5 Dual 2.0, AJA Kona 2, Medea FCR2X
Kurt Hennrich
October 6, 2005 at 3:09 pm[Walter Biscardi] “Note that this filter does nothing for the blacks”
my ‘mastering’ plugin also takes care of the blacks. see https://www.1z1.at/plugins/
++ the workflow walter biscardi described, by color correcting the clip/sequence first, is very rcommended.regards,
kurt -
Walter Biscardi
October 6, 2005 at 3:16 pm[Kurt Hennrich] “my ‘mastering’ plugin also takes care of the blacks.”
No offense, but I’m not really sure what’s different about your filter and the Levels filter included with FCP. It does a perfect job of keeping the blacks legal for HD broadcast material here.
Now I saw some other filters on your site that look interesting, but quite honestly, the Levels filter does an outstanding job for keeping the blacks safe.
Kurt Hennrich
October 6, 2005 at 3:50 pm[Walter Biscardi] ” I’m not really sure what’s different about your filter and the Levels filter included with FCP. It does a perfect job of keeping the blacks legal for HD broadcast material here. “
I just did a quick test with the levels filter because I did’nt use it for a long time:
you are right, it cuts super blacks perfect and also limits whites to 100%. but it does not bring ‘hot’ signals within legal RGB gamut range which my plugin does just with the default settings (among some other useful stuff).
but for most situations the levels filter seems to be just fine – thought according its name its intended for a slightly different use.
kurt
