Activity Forums Apple Final Cut Pro Broadcast Safe Color Correction – trying to Blowing out whites
  • Broadcast Safe Color Correction – trying to Blowing out whites
    Posted by Brad Hilton on September 18, 2013 at 9:18 pm
    I couldn’t find a proper section for this and since I’m using FCPX I’d figured I’d ask here. I am finishing up an Ad that will broadcast and I’m trying to get a certain look. I want some area’s to be overblown with a flare type look. The problem I run into is that I have my look, I add the broadcast safe filter, or try to tune down the white clipping with the color corrector, and it looks like crap.
    Is it just a matter of playing and tweaking to get something close to what I want? Or does anyone have any tips? How do movie’s and tv shows that use strong lens flares or blowouts not cause problems?
    Oliver Peters replied 12 years, 11 months ago 2 Members · 1 Reply
  • Oliver Peters
    September 18, 2013 at 9:54 pm
    Make sure the broadcast safe filter is “downstream” of everything. You can do this by adding a adjustment layer generator as a connected clip (search for free ones or use Basic Title and remove any text) and then apply the safe filter as an effect to this clip.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
