Activity Forums Broadcasting Broadcast requirement
  • Broadcast requirement
    Posted by Dan Newton on April 21, 2009 at 5:04 pm
    Hey Guys
    Need some urgent help — I have been given the new format — from a television station — they will not use digi or sp for broadcast but mpeg 2
    now please fund below the exact requirements:-
    Dear All,
    Please be informed that henceforth all TV commercials to be aired on …. Television is not required in Digi Beta or Beta SP format: Kindly note new material specs:
    File Format : Mpeg 2 or Mpeg 4
    Duration in seconds : Multiples of 5 for eg: 10, 15, 20, 25 etc…
    Deadline for airing : 4 -5 working days after receipt of material
    There is no change in Material requirement for sponsorship tags. However, please note the same for your reference:
    5 sec mute mpeg ( in case of animation) or jpeg ( for static image). Mpeg size not to exceed 4 MB. Material to be sent by email
    Voiceover format:
    Dan Newton replied 17 years, 4 months ago 3 Members · 4 Replies
  • Ron Gerber
    April 21, 2009 at 5:59 pm
    Here are the steps my company has been telling everyone to use for MPEG2 Delivery using Sorenson. Most likely they will be similar to what your station wants – It would probably be best to send them a test file well in advance to trouble shoot the problems – usually the problems will be audio related.
    1. Drag QuickTime reference movie (or a Regular QT movie) into Sorenson.
    2. Select MPEG-1/2 drop down, Select “DVD_NTSC_LG” by dragging that to the QT reference movie
    3. Double click on the DVD_NTSC_LG to open up it preferences.
    Video:
    Set as follows: format constraints: DVD (MPEG2); stream type: Program; Codec: MPEG-2 Video; Method: 1-pass CBR; data rate: 9570 (or you might have to do 2 pass VBR and set all avg, max * Min to 9570); format: NTSC; frame size: 720 x 480; frame rate: 29.97; aspect ratio: 4:3; field encoding: bottom field first; I frame rate: 15
    Audio:
    Set Audio to MPEG PCM Audio (or you might have to try the Layer 2 setting if the station tells you there’s no audio)
    Sample 16
    Sample Rate 48000
    Channel Stereo
    5. press ok & then squeeze it
    Good Luck and if you have stock in FedEx, it might be a good time to sell.
  • Joey Burnham
    April 21, 2009 at 6:22 pm
    It’s surprising that they would ask for an Mpeg 2 and not give you any other specs besides that.
    Anyways, just bring your file into compressor. There is an Mpeg 2 program stream preset which would probably work.
    Joey
  • Dan Newton
    April 24, 2009 at 6:59 pm
    Hey
    Thanks for the step by step —
    So I have done the exact specifications you have said — so hopefully the TVC won’t be rejected.
    thanks so much
  • Dan Newton
    May 2, 2009 at 6:50 pm
    Hey
    One question —-
    what about the data rate — will it stay as 1536
    please advise
