Activity › Forums › Apple Final Cut Pro Legacy › Broadcast render problem.Please Help!
  • Broadcast render problem.Please Help!
    Posted by Amit Ghildiyal on August 20, 2009 at 10:31 pm
    I send out 4 hours of programming (HD and SD), rendered out in 4 parts (quicktime) to a broadcaster every week.
    The sequence settings are
    NTSC DV 3:2
    720*480
    PIXEL ASPECT: NTSC – CCIR 601/ DV 720*480
    FILED DOM: LOWER (EVEN)
    TIMEBASE : 29.97
    Compressor :DV/DVCPRO – NTSC
    Audio:
    48 htz, 16 bit channel grouped
    I render it out according to their requirements,
    Quality : medium
    frame rate : 29.97
    Scan mode: interlaced
    aspect:4:3
    Dimensions : 720*480 (640*480) (compressor native)
    sound :
    format :integer (Little Indian)
    sample :48htz
    sampl :16 bit
    channel:stereo (LR)
    Preped for internet streaming (Fast start)
    Despite following this procedure and making sure dropped frames is checked in the seq settings, for some reason some files transfer onto their server and others dont. This has happened a lot lately.
    Kindly help.
    Amit Ghildiyal replied 17 years, 1 month ago 2 Members · 2 Replies
  • Russell Lasson
    August 20, 2009 at 11:44 pm
    The only things that stand out as being strange to me are:
    1. Broadcaster asking for a DV file
    2. Setting DV file to medium quality
    3. Including a fast start for streaming on a DV file
    If you really need a fast start on the DV file, simply exporting the sequence at current settings won’t do it. You’d need to use Compressor or QT Conversion for that.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Amit Ghildiyal
    August 20, 2009 at 11:58 pm
    Thanks for your quick response Russell.
    I do use QT Conversion for the rendering procedure. I also forgot to add a few “minor” details .Sorry,. Here they are.
    1)The rendering happens on Macs.
    2) The QT files are transferred onto the server
    3) the files on the server are transferred onto a hard drive (formatted for windows xp), connected to a windows xp machine.
    4) The drive is shipped to a different state. Protectvie box says “do not x-ray”
