Activity Forums Broadcasting Broadcast Quality mpeg2 – Software to transcode?
  • Broadcast Quality mpeg2 – Software to transcode?
    Posted by Aaron Villa on February 14, 2012 at 8:04 pm
    I was wondering if anyone could tell me what software out there can transcode from quicktime ProRes to high bitrate mpeg2 described below?
    I have Final Cut Studio 2 suite and Adobe CS3 suite. I looked at the Apple compressor 4 manual, but all the settings for mpeg 2 are the same as the old one and only go up to 40mbps for Mpeg2. Anyone using newer CS5 to do this?
    Video High Definition
    • Video Codec: MPEG2
    • Bit-rate: 80 Mbps; (min 50 Mbps if A/V quality approved)
    • Bit-rate mode: CBR
    • GOP: I frame only
    • Resolution: 1920×1080
    • Scanning: Progressive
    • Frame Rate: 23.98 (23.976)
    • Profile: 422@HL
    • Aspect Ratio: 16:9
    • Closed Captioning: CEA-708 NADBS
    • Container: MPEG2 Transport (.ts) Preferred Program Stream (.mpg) or MXF (.mxf)
    Video Standard Definition
    • Bit-rate: 50 Mbps; (min 25 Mbps if A/V quality approved)
    • GOP: I frame only
    • Resolution: 720×480
    • Scanning: Interlaced
    • Frame Rate: 29.97
    • Profile: 422@ML
    • Aspect Ratio: 4:3
    • Closed Captioning: CEA-608-B
    Aaron Villa
    Video Post Production | DVD Authoring | 3D Animation
    aaronvilla.com
    Aaron Villa replied 14 years, 7 months ago 1 Member · 1 Reply
  • Aaron Villa
    February 15, 2012 at 7:18 pm
    Someone else recently told me to checkout their Episode software. I was kinda hoping there were some other options out there, but it seems like this is the software for it.
    Thanks.
    Aaron Villa
    aaronvilla.com
