Activity Forums Apple Final Cut Pro Legacy Broadcast output settings
  • Broadcast output settings
    Posted by Gabriele Gismondi on April 16, 2010 at 8:57 am
    thanx to Your help i finnaly came out of my timeline with a Prores Qt movie that i like.
    I’d be giving this to regional TVs and i’m not sure about specs to keep in terms of colour/contrast since i’ve made my levels for the web.
    Is there a way to keep levels in the TVs range and what about Broadcast effect in the effects tab..i don’t get the use of it..and i do not have an ext monitor..
    thanx for help
    Michael Gissing replied 16 years, 5 months ago 3 Members · 4 Replies
  • Chris Poisson
    April 16, 2010 at 2:20 pm
    Use your scopes to check your levels. Different stations will have different requirements, you need to check with each.
  • Gabriele Gismondi
    April 16, 2010 at 2:30 pm
    ok, thanks, i’ll be checking for “green circle” on clips to make sure..i’m on the right way..
    tnx again
  • Chris Poisson
    April 16, 2010 at 2:35 pm
    Yes, but don’t forget your scopes, I use the waveform monitor to check black and white levels. Also, you might try the broadcast safe filter and see what that does to your levels.
  • Michael Gissing
    April 16, 2010 at 10:28 pm
    Broadcast safe is not reliable after render. Search this forum as there are a few better ways to make you clips broadcast safe for both levels and Chroma.
