Activity › Forums › Apple Final Cut Pro Legacy › Broadcast Monitors V. Cinema Displays
  • Broadcast Monitors V. Cinema Displays
    Posted by Franco Bogino on April 25, 2006 at 4:15 pm
    Hi
    I wanted some imput on a video monitoring issue.
    I am working on Hi Def programming with a G5 FCP setup with cinema displays. We have a cinema display connected to a Decklink multibridge extreme.
    We are waiting on budgets etc to get a proper broadcast monitor, but I have been told that the Apple Cinema Display is fine.
    I am, very sceptical on this as I am actually onlining the shows as well, including grading and making sure they adhere to tech specs.
    I know the Cinema displays are superb for graphics and photo retouching, but am not sure that they provide a correct representation of video which will ultimately be played out on tube televisions.
    I would be grateful to hear from anyone with any experience in this field.
    Franco
    Drizzt_g replied 20 years, 5 months ago 3 Members · 3 Replies
  • Paul Ingvarsson
    April 25, 2006 at 4:40 pm
    Hi Franco,
    If you need to adhere to the Tech Specs you will be best off to use a legaliser (I use an Eyeheight Multidef Unit) this means that if it looks good – then it is good (providing your monitor can look at the output of the legaliser). I’m sure that the guys at aji doing the budget will not stretch to a Vectorscope/Rasterizer to help you with the grading/level checking.
    Because you are doing multi standard finishing in interlaced format you will need a monitor that will handle interlace well… I use a Vutrix monitor form Frontiniche that displays interlace very well and is calibrated for colour over a long period of time, the blacks are also good and it a has a glossy glass front which makes my clients check to see if it’s CRT or not…
    Having said that you also need to protect yourself for downconvert issues – I would recommend a grade 1 SD monitor on your SDI downconvert output, that way you are protecting yourself for everything.
    It’s an expensive game being sceptical! I would say they would be happy with a Dell 24″ display for taking component HD input and a legaliser. I have this on my FCP setup – but I think the dell is quite bad at ghosting (or lag) and it deals with interlace badly.
    Hope this helps,
    Paul
    Freelance DS/Symphony
    London
  • Franco Bogino
    April 26, 2006 at 12:34 am
    Hi Paul
    Every question throws up new dilemmas! I’ve never really had to analize the kit I’m using to quite this level – it’s usually just there ready for me to use. Anyway, here’s a quickfire round:
    1. I was thinking of using the legaliser filter within FCP, will this not do the job?
    2. Same for the scopes, they seem to work – but are they trustworthy?
    3. The Decklink has a function to show interlacing issues on the Cinema display. So far it seems to have successfully displayed interlacing flicker, though there may be issues I am unaware of and not looking out for.
    At the moment I am thinking more about whether the Cinema display can be calibrated to accurately display colours and light balance of a video image, so that I can grade by eye. We’re not at the mastering stage yet, so I hadn’t really considered the necessity for monitoring component imputs/ outputs.
    Maybe I should pay you a visit!
    Anyway, thanks for the sound advice.
    Franco
  • Drizzt_g
    April 27, 2006 at 10:52 am
    I think the new MXO box from Matrox is doing exactly that.
