Activity › Forums › AJA Video Systems › broadcast monitor vga to LSe breakout cable SDI in
  • broadcast monitor vga to LSe breakout cable SDI in
    Posted by Amit Ghildiyal on December 3, 2009 at 9:25 pm
    My Kona LSe is already connected to a digibeta. So all SDI in & out points and the 60 pin connector are used up. I have a old sony HR Trinitron broadcast monitor i need to attach into this setup. My only option (according to my limited knowledge) is to connect it to the breakout cable’s SDI input. The monitor’s wire itself is a 1 to 3 sdi for the RGB on one end and a (15 pin) VGA. How to i get my monitor connected to the LSe and get feed? please help
    I work on a mac pro duel core intel xeon, 12 gb ram.
    Arnie Schlissel replied 16 years, 10 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    December 3, 2009 at 10:56 pm
    If your digiBeta has component out, you could just run that into the monitor. Otherwise, you’d go straight from the Kona to the monitor via component.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
