Activity Forums Broadcasting Broadcast monitor to G5?
  • Broadcast monitor to G5?
    Posted by Benjamin Pastrana on April 27, 2005 at 2:00 pm
    hi
    I am new at this. I have a G5 and would like to buy
    a broadcast monitor. Do I need an adaparter video card
    for this or there is anyway I can attach the monitor
    to the secondvideo output of th G5?
    thanks
    benjamin
    Mike Johnson replied 21 years, 4 months ago 3 Members · 2 Replies
  • Robert Hotz
    May 6, 2005 at 3:44 am
    You need either a PCI card that wouold be installed in your G5 that gives you a video output, or a DV to analog video converter. This would plug into your firewire port. Set up preferences in your edit system to send video out firewire port. You could also use any camcorder with firewire connection and then an analog output. Most DV cams have this.
  • Mike Johnson
    May 9, 2005 at 2:30 pm
    there are also adapters that you hook up to your second monitor output that converts it to Composite/S-Video/Component.
    Thats probably the cheapest solution.
    I own one of those myself, it’s called Keylite.
