Activity › Forums › Adobe After Effects › broadcast leval color correction in ae
  • broadcast leval color correction in ae
    Posted by Nikhil Madhav on October 2, 2011 at 7:14 am
    hi i am a freelance motiongraphics artist from india. i want to know how to atchive a broadcast quality color correction in ae.
    because the colors we saw on our normal monitors are seen completely different on broadcast monitors and these monitors are expensive.
    so did anybody know how to achive broadcast leval color correction in ae by using normal led monitors.
    Nikhil Madhav replied 14 years, 12 months ago 3 Members · 3 Replies
  • Jules Bodenstein
    October 3, 2011 at 10:30 am
    In order to monitor your playout accurately you will need a calibrated monitor. The reason broadcast monitors are expensive is that they a fully calibratable and have numourous I/O options.
    Something you could do to make the images on your monitor more representative of the output is to load some SMPTE bars in AE and then adjust your monitors display settings until the bars look correct. This will not be as good as having a broadcast monitor but it will improve your monitor view without costing a fortune
    Gaz Evans
    Workflow Technician
    The diROOM
    https://www.diROOM.com
  • Todd Kopriva
    October 4, 2011 at 3:47 am
    Are you using the color management features in After Effects?
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Nikhil Madhav
    October 4, 2011 at 4:03 pm
    thank you for your kind replay
