Activity › Forums › Apple Final Cut Pro Legacy › Broadcast legal levels…..
Posted by Adrian Zehn on February 20, 2007 at 12:21 amHi,
Another issue I have been dealing with is how to make the DVCProHD sequence luma and chroma levels broadcast legal….
Research indicates that the FCP Broadcast Safe filter doesn’t work……does anyone have experience with the 1z1 filter? (https://www.1z1.at/plugins/#mastering)? What workflows are people using to make their FCP DVCProHD sequences broadcast legal?
AZ
Harry Bromley-davenport replied 19 years, 7 months ago 5 Members · 8 Replies -
Shane Ross
February 20, 2007 at 12:25 amWith FCP 5.1.2 the Broadcast Safe filter was fixed…at least for me. Others state that it was never broken, others side with me. But, now it works.
What do I do? Use the 3-way color corrector and color correct shot by shot. Then throw that filter on at the end to just be sure.
Shane
Littlefrog Post
http://www.lfhd.net -
Adrian Zehn
February 20, 2007 at 1:05 amThat’s good to know…..
What do you do about FCP text? We have a lot of FCP title tool text that is white with a black drop shadow. Even when we put the broadcast filter on these, the Range Check symbol still says these titles are not broadcast safe.
AZ -
Shane Ross
February 20, 2007 at 1:13 amI use Title 3D, the one under the BORIS menu. And I set my white text to about 85%.
Shane
Littlefrog Post
The Edit doctor
February 20, 2007 at 1:58 amAdrian,
Leave your email and I’ll send you a couple a filters to try out regarding both of your issues.
Walter Biscardi
February 20, 2007 at 3:57 am[Adrian Zehn] “Research indicates that the FCP Broadcast Safe filter doesn’t work”
We have no issues at all with the Broadcast Safe Filter, but know that it only legalizes Luma, not Chroma. I adjust chroma for each shot as I grade it.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Adrian Zehn
February 20, 2007 at 8:14 pmHi Walter….
Thanks for this……now the manual claims the filter will fix the chroma as well….are you saying this doesn’t work properly?
AZ
February 21, 2007 at 4:05 pmPlease, Mr Edit Doctor, could you send those filters to me too? I’d be most grateful if you have the time.
Best
Harry
