Activity Forums Compression Techniques broadcast help
  • broadcast help
    Posted by Dan Newton on April 21, 2009 at 5:05 pm
    Hey Guys
    Need some urgent help — I have been given the new format — from a television station — they will not use digi or sp for broadcast but mpeg 2
    now please fund below the exact requirements:-
    Dear All,
    Please be informed that henceforth all TV commercials to be aired on …. Television is not required in Digi Beta or Beta SP format: Kindly note new material specs:
    File Format : Mpeg 2 or Mpeg 4
    Duration in seconds : Multiples of 5 for eg: 10, 15, 20, 25 etc…
    Deadline for airing : 4 -5 working days after receipt of material
    There is no change in Material requirement for sponsorship tags. However, please note the same for your reference:
    5 sec mute mpeg ( in case of animation) or jpeg ( for static image). Mpeg size not to exceed 4 MB. Material to be sent by email
    Voiceover format:
    Craig Seeman replied 17 years, 4 months ago 2 Members · 1 Reply
  • Craig Seeman
    April 21, 2009 at 5:10 pm
    You may need to find out whether they need a Program or a Transport stream or whether either is acceptable. You probably need to get a max data rate spec and probably 4:2:0 vs 4:2:2 color space.
    I use Episode and encode to MPEG2 Program Streams at 18,000kbps 2 Pass CBR, 4:2:2 for DGFastchannel for spot distribution.
    But you really need details from them to make a file for broadcast.
