Activity Forums Adobe Premiere Pro Broadcast files for Digital Delivery
  • Broadcast files for Digital Delivery
    Posted by Todd Terry on September 29, 2009 at 3:14 pm
    Hey gang..
    Hope no one minds, I’m going to cross-post this in one other forum since I’m not sure where the best answer lies.
    We are a tiny little production company that mostly deals with broadcast commercials. We have yet to do any digital delivery, we still send out zillions of BetaSP dubs to television stations every year.
    However, Comcast is now forcing our hand… we’ve received notice from them that here in our city they will no longer be coming by to pick up (or accept) Beta dubs. We have to either do digital delivery, or FedEx dubs to a Comcast office in another city.
    The problem with digital delivery is, we have not been able to make decent-looking files for them. They are requesting either Mpeg2 or Quicktime files, and frankly the test files that we have made look like crap. No matter what output settings we try or how much we crank up the juice, they are fuzzy (and sometimes have fields reversed).
    How are you guys doing this? Any tips on a successful workflow would be most appreciated.
    We are a PC house and all of our suites run Premiere… we have an ancient suite still running PremierePro 6 on a Canopus Storm2 machine… and two other Matrox AXIO LE suites that run CS3 and CS4, respectively.
    Thanks in advance if anyone has any helpful solution,
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
    Michael Banks replied 15 years, 6 months ago 9 Members · 27 Replies
  • 27 Replies
  • Vince Becquiot
    September 29, 2009 at 3:37 pm
    Hi Todd,
    Thanks for stopping by. At this point in time, the best solution we’ve found was to export to Quicktime Animation from Premiere, “without downscaling” if the source is HD.
    I always pick square pixels. 640×480 for SD 4:3, 854×480 for SD 16:9
    If dowscaling is needed, I pass the file through After Effects, creating a new SD Comp and exporting again from there, also making sure that AE keeps the right field order, I think it does progressive by default.
    The final export is done through Quicktime pro. Either Motion JPEG or H.264
    The other reason this process is needed is because exporting directly to H.264 for example will cause that dreaded gamma shift, and Quictime pro just seems to get me a more even and reliable compression.
    I’m not sure about the field order issue. I sometimes see weird things happen when getting files that were captured in FCP. I usually end up converting these to Animation prior to import, just in case.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Oliver Maingay
    September 29, 2009 at 4:56 pm
    For broadcast I am very surprised you have deliveries accepted with those specs. Square pixels are for computers or HD, not SD televisions and the aspect ratio should be 720×480 for NTSC.
    If you are editing uncompressed I would recommend delivering uncompressed, either 10-Bit using a codec such as Blackmagic or 8-Bit if file sizes are an issue. The station can then encode to their MPEG-2 specs for broadcast.
    If you want to go down the MPEG-2 route you need to contact the network for their specifications.
    Hope that is some help,
    Oliver
  • Todd Terry
    Thanks Vincent…
    Most of these are SD delivery projects that started as SD, so the downscaling is not an issue.
    I believe my editor tried exporting as a Quicktime Animation, but still had very poor results.
    We have just not been able to hit on the right recipe. I’ll pass your notes on to him and see if he has missed anything… I’m trying as well. We’ve had two suites cooking on this for two days and still can’t seem to get acceptable results. Grrrrr.
    T2
    Todd Terry
    Creative Director
  • Todd Terry
    September 29, 2009 at 5:01 pm
    [Oliver Maingay] “If you are editing uncompressed I would recommend delivering uncompressed, either 10-Bit using a codec such as Blackmagic or 8-Bit if file sizes are an issue. The station can then encode to their MPEG-2 specs”
    Yes, we edit uncompressed… but I can’t deliver such gigantic file sizes… our masters are typically 10-bit uncompressed AVI files that are pushing a gig for a :30 spot…. and I’m pretty sure Comcast wouldn’t be able to handle them or the format… they specifically asked for mpeg2 or mov files.
    [Oliver Maingay] “you need to contact the network for their specifications”
    We have, and they are clueless. They are asking (and requiring) something that they don’t even know how to properly ask for.
    It’s frustrating…
    T2
    Todd Terry
    Creative Director
  • Vince Becquiot
    September 29, 2009 at 5:11 pm
    Oliver,
    I was referring to intermediate transfers between Premiere and After Effects / Quicktime.
    Misinterpreted PAR seems to be the biggest issue I see around between applications, often creating pixelated and soft exports.
    I find that this creates the least issues, but your final export from Quicktime Pro can be anything you want, and certainly should adhere to the specs listed by the station.
    Vince Becquiot
    Kaptis Studios
  • Vince Becquiot
    September 29, 2009 at 5:14 pm
    Todd,
    Feel free to post all your settings on the next export.
    Vince Becquiot
    Kaptis Studios
  • Oliver Maingay
    September 29, 2009 at 8:01 pm
    Though we’re a facility in the UK, we have delivered in MPEG-2 to US networks digitally before, I will have their spec at the office and will post it tomorrow when I get in. To start with it will be:
    MPEG-2 / 720×480 / 29.97fps / DV (or DV Widescreen) Pixels Aspect / 8Mbps / Lower Field First / and I *think* GOP N=12 M=3
    For QuickTime, one client requests QuickTime encoded to the following spec and results are often very good. Probably worth a try:
    Codec: Photo JPEG @ 75% Setting
    Frame size & rate as above.
  • Daniel Low
    September 29, 2009 at 9:21 pm
    [Oliver Maingay] “If you are editing uncompressed I would recommend delivering uncompressed, either 10-Bit using a codec such as Blackmagic or 8-Bit if file sizes are an issue. The station can then encode to their MPEG-2 specs for broadcast. “
    Stations don’t want to have to re-encode, they want something that works on their systems.
    Certainly in my experience.
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today
  • Daniel Low
    September 29, 2009 at 9:23 pm
    [Vince Becquiot] “I find that this creates the least issues, but your final export from Quicktime Pro can be anything you want, and certainly should adhere to the specs listed by the station. “
    As much of a fan of QT as I am (having worked with it before it was even available to the public), there are now too many ‘issues’ with it for it to be reliable for use as a format for delivery to a broadcast playout centre.
  • Daniel Low
    September 29, 2009 at 9:25 pm
    [Todd Terry] “I believe my editor tried exporting as a Quicktime Animation, but still had very poor results”
    Not the right format to choose, like the name implies, suitable for Animation, not video. Oddly enough though, PhotoJPEG would be a much better choice.
Page 1 of 3
