Activity › Forums › Adobe Premiere Pro › Broadcast delivery kicked back due to chroma and compression rate.
  • Broadcast delivery kicked back due to chroma and compression rate.
    Posted by Brian Covalt on May 31, 2018 at 7:32 pm
    We’ve sent out a video for broadcast and it was kicked back to us for 2 reasons:
    1. The spec sheet requests 4:2:2 chroma subsampling, what we provided was 4:2:0.
    2. File provided was compressed at 4,657 kb/s and they need the file above 145 mb/s.
    I’m stumped because we delivered ProRes(HQ) which should be 4:2:2, and also above the compression rate they listed.
    To give a bit more context in our workflow –
    shot on RED, edited (I’m not sure how that editor transcoded), colored, and sent back to us as ProRes4444.
    We then put a Video Limiter adjustment to the final colored video and exported as ProRes(HQ).
    Is there a way to view what the chroma subsampling is? I’d like to confirm that our export is indeed only 4:2:0, but don’t know how to see that information. I also don’t know how to view the compression rate (how are they seeing 4,657 kb/s?).
    Is there a chance that the RED footage was transcoded down to a format that was only 4:2:0 at some point, and that’s why our ProRes(HQ) export is showing only 4:2:0?
    Thanks for the help!
    Brian Covalt replied 8 years, 3 months ago 2 Members · 2 Replies
  • Daniel Waldron
    May 31, 2018 at 9:04 pm
    Was the video exported to ProRes on a Mac, or on a PC using a third-party encoder or plugin? You can try software called MediaInfo to view detailed codec information. I haven’t used it, but I’ve known editors who have… Hopefully that will give you some answers.
  • Brian Covalt
    May 31, 2018 at 11:23 pm
    That app is helpful, thanks for suggesting it!
