Activity › Forums › Adobe Premiere Pro › Broadcast Delivery File Spec Help!
  • Broadcast Delivery File Spec Help!
    Posted by Steve Lloyd on November 26, 2020 at 3:08 pm
    Hi guys,
    I’ve got some broadcast billboards that need to deliver and the tech spec’s request some stuff I don’t know how to check. Can anyone help with how to check these things?
    Video Levels – “Must comply with ITU 709. Luminance (Y) must not exceed 714mv (100 IRE units) & Chrominance levels in the Y/Pr/Pb domain must not exceed 785mv (110 IRE units).” How do I check if my edit complies with these, and if it doesn’t, make it do so?
    Timecode – “Timecode must be present in QuickTime .MOV as a timecode track“. Is this just clicking the ‘Set Start Timecode’ setting when exporting, or something different?
    Any help, advice, pointers you guys could provide would be most appreciated.
    Thanks in advance,
    Steve.
    Shane Ross replied 5 years, 10 months ago 2 Members · 1 Reply
  • Shane Ross
    November 26, 2020 at 7:58 pm
    “Video Levels – “Must comply with ITU 709. Luminance (Y) must
    How do I check if my edit complies with these, and if it doesn’t, make it do so?”
    You need video scopes to check this. There is a line at the top that is the ceiling of 100 IRE…lots of lines in the middle…and then the floor of 0 IRE. You need to make sure your video doesn’t stray outside of that. Some broadcast monitors have scopes built in, and you feed that a video signal from a capture card or device. There are external devices that have scopes, but they are spendy. And a few apps have internal scopes, like Resolve. And software solutions like SCOPEBOX.
    You can also try to use the BROADCAST SAFE plugin that Premiere has. That’s supposed to crush things on both ends to meet that spec, but sometimes it doesn’t get it quite all the way, and some things can hit 101 or 102 IRE. But that might be an option…if you don’t have the money nor expertise to invest into and install external options.
    “Timecode – “Timecode must be present in QuickTime .MOV as a timecode track“. Is this just clicking the ‘Set Start Timecode’ setting when exporting, or something different?”
    This would mean exporting a file type that supports embedded timecode. So ProRes would support this, and DNxHD. And the timecode would be what your sequence timecode is. If it starts at 1:00:00:00…then it will embed it into the export starting at that number. DO you know if they need drop-frame or non-drop frame timecode?
