Activity Forums Compression Techniques Broadcast compression request how to make in Compressor??
  • Broadcast compression request how to make in Compressor??
    Posted by Robin Lewis on February 16, 2011 at 7:35 pm
    I need to make a deliverable file and only have compressor, i have been asked for the bellow compressions from the broadcaster but can not match it as much as i try in compressor> For exsample I can not get any Mpeg 2 file to be over 40Mbps but they want 50 Mbps
    Can anyone help?
    Broadcast Quality
    Video Format: MPEG-2 422P@ML 4:2:2
    Video Bitrate: 50 mbps I Frame Only
    Resolution: 720×608 (we can accept 720×576)
    Frame Rate: 25
    Rate Control: CBR
    Audio Channels: 2Ch Stereo pair
    Audio Bitrate: Mpeg 1 layer 2 (we cannot accept uncompressed PCM audio)
    Audio Bit Rate: 384 kbps
    Audio Sample Rate: 48 kHz
    Filed dominance: 1st field / Upper field first.
    We require Broadcast Standard 625/50 (PAL) @ 720×608 resolution including VITC on lines 19 & 21.
    Review Quality
    Video Format: MPEG-2 Main Level @ Main Profile
    Video Bitrate: Minimum 5mbps Short GOP (IBBP)
    Resolution: 720×576 PAL
    Frame Rate: 25
    Rate Control: VBR
    Audio Bit Rate: 128 kbps
    thanks
    Mark Luigjes replied 15 years, 5 months ago 4 Members · 3 Replies
  • Craig Seeman
    February 16, 2011 at 7:57 pm
    You’re seeing some of the limits of Compressor. Max bitrate of 40Mbps. It can’t add VBI either. I also don’t think it can do i-Frame only. IP, IBP, IBBP. I don’t claim to be a Apple Compressor expert but its limitations are why I use Telestream Episode.
  • Jeff Greenberg
    February 23, 2011 at 3:53 am
    [Robin lewis] “Video Format: MPEG-2 422P@ML 4:2:2
    Video Bitrate: 50 mbps I Frame Only”
    422 check.
    Bitrate 40 (fail)
    GOP: IP (fail)
    I stopped there.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Mark Luigjes
    April 8, 2011 at 1:41 pm
    Craig, exactly my thoughts 🙂
