Activity › Forums › VEGAS Pro › Broadcast Colors
  • Broadcast Colors
    Posted by Kevin Reinicke on January 26, 2009 at 7:11 pm
    Please guys I need your help,
    this is my first project (720p, 23,976) that gets broadcasted on satellite TV and so I have to deal with the NTSC Legal Colors and I need some help. As far as I know the NTSC legal colors are between 16-235 RGB. I am within this range, but my vector scope image looks WEIRD, there are HOLES in between !!! (see yourself)
    my project´s video scope image used to look like this before everything: https://s8b.directupload.net/images/090125/omn94jtg.jpg
    when I apply “levels” and “broadcast colors” to it, I can bring the colors down within the 16-235 range and it looks like this:
    https://s7b.directupload.net/images/090125/oh35dwip.jpg
    But the video becomes a bit pale. When I try to fix this with some contrast plugin, I see holes in the video scope image.
    https://s8b.directupload.net/images/090125/7jp22a5w.jpg
    is this a problem ???? according to my video scope image (as you can see on second and third pic) I am within the 16-235 legal color range, is this all that I have to do to avoid distortion or is there more that I have to be aware of?
    thanxs in advance
    Kevin Reinicke replied 17 years, 8 months ago 2 Members · 2 Replies
  • Steve Rhoden
    January 28, 2009 at 10:14 am
    First thing, if your project is geared for broadcast, you
    cannot be using your PC Monitor for viewing your final output.
    You need a properly configured broadcast monitor to be doing
    your viewing in or at least a well tuned television.
    Adjusting your colors for broadcast specs will look odd
    on your pc monitor..(as you are seeing)….you need to
    have an ieee firewire external preview hooked up.
    You are using the histogram…Personally i often use the
    vectorscope for a clearer view of making sure that all color
    levels are within the legal broadcast limit.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Kevin Reinicke
    January 30, 2009 at 3:09 pm
    Thank you Steve,
    Image this was from a calibrated monitor,
    Is it normal that you can find holes between the color range? (like on my pics?)
