Activity › Forums › Adobe After Effects › broadcast color safe
Posted by Ryan Santos on January 5, 2011 at 10:42 amIf all I need is to make video broadcast color safe, do i need to have a calibrated monitor or will the scopes in Color Finesse suffice?
If I apply the Broadcast Colors effect to a footage, does that automatically make the footage broadcast color safe? Thanks and God bless.
Ryan Santos replied 15 years, 8 months ago 4 Members · 5 Replies -
Michael Szalapski
January 5, 2011 at 2:29 pmAs I understand it, pretty much yes to both.
You can use the scopes in Color Finesse to see what’s outside the color range and to correct for it, but I feel you’ll get better color if you can preview it on a broadcast monitor. At least you’ll be able to see what you’re doing.
Also, the Broadcast Colors filter does make it broadcast legal, you’d probably be better off doing it in Color Finesse though. You can make colors broadcast legal by applying a levels effect too. (input sliders to 235 and 16) 🙂 but again, you’d get better quality fiddling with the colors manually in Color Finesse.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Todd Kopriva
January 5, 2011 at 5:44 pmSee this page. It gives tips and instructions for various methods.
One method is to use the Broadcast Colors effect, but not to automatically make the changes for you. Rather, you can use it to identify the areas that need adjustment so that you can make the adjustments yourself.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Michael Szalapski
January 5, 2011 at 6:00 pmYou’re not disagreeing with me Dave, you’re merely clarifying what I said. 🙂
– The Great Szalam
Chris Wright
January 5, 2011 at 10:34 pmcolor finesse’s smart limiter is the simplest way because it smoothes the luma and chroma transition automatically instead of lopping it off.
https://technicolorsoftware.hostzi.com/
Ryan Santos
January 6, 2011 at 12:19 amThanks guys for your answers. Really very helpful. God bless.
