Activity › Forums › VEGAS Pro › Brining Vegas Project Files to FCP
  • Brining Vegas Project Files to FCP
    Posted by Bryan Sundstrom on May 9, 2008 at 10:13 pm
    Question: Can I pull all the layers of a project file from Sony Vegas and export them to be able to continue the project in Final Cut Pro?
    My editor made an amazing project for me in Vegas and provided me with the entire folder containing every piece of media and all the versions of the Sony project files. There are about 8 layers and I need to make adjustments that cant be done after rendering it out and then bring that mastered copy into FCP. Is there a way to bring the project over without having to go through a compression process to be able to have the layers, effects, etc…?
    Any help with this would be IMMENSELY helpful!
    Bryan
    Bryan – bryansundstrom@gmail.com
    Edward Troxel replied 18 years, 4 months ago 2 Members · 1 Reply
  • Edward Troxel
    May 10, 2008 at 10:17 pm
    Final Cut cannot open Vegas projects. For simply projects, you might be able to output an EDL from Vegas and import that. If this is a complicated composition, you will be better off letting him make the needed changes and giving you rendered output.
    Edward Troxel
    JETDV Scripts
