Activity Forums Avid Media Composer Bringing Media Back Online
  • Bringing Media Back Online
    Posted by Chip Hess on April 29, 2017 at 4:54 pm
    Here is where lack of formal training fails me.
    I have a large project I recently took offline, using Media Mover.
    I copied the Avid Media to another external drive. I consolidated
    to that drive. Some media is showing offline. I had done some work
    on the project and inadvertently created some new media on original drive.
    So that is not showing up when using media folder from the second drive.
    I’d like to delete copied media on second and recopy from original,
    so I can grab ALL the media and correctly copy to the second external.
    My original drive is almost full, so moving it to larger second external
    buys me a lot more space.
    I have all the original media I had moved offline on the original drive,
    using Media Mover. I then used MM to move it back online on original drive.
    Now, after moving the files back online on original drive
    using Media Mover, the media still shows in Avid as offline.
    I deleted the database files.
    I only have original drive mounted, so Avid cannot reference
    the second drive. But I already consolidated, so I suspect
    that is where I made an error.
    I know the media is all there, I just need to get Avid
    to recognize it again on the original drive.
    What do I need to do?
    Chip Hess replied 9 years, 4 months ago 2 Members · 4 Replies
  • Glenn Sakatch
    May 1, 2017 at 1:42 pm
    Haven’t used Media mover for years. What is the name of the folder Media Mover created when it originally took the media offline?
    Did you move that whole folder across when you moved it back online?
    Where did you put that folder?
    You said you deleted the database…did Avid successfully rebuild it?
    One of these answers is probably the solution to your issue.
    Your new media that was accidentally put on the original drive is probably in a “1” folder.
    When you put the original media back on-line, did you put it in a numbered folder? Avid needs a numbered folder to be able to rebuild the database.
    Those folders ofcourse need to be in the proper location. Root of your hard drive/Avid MediaFiles/MXF/”number”
    Once Avid rebuilds the database, then you can rename that numbered folder.
    If the database was successfully rebuilt the first time you deleted it, then you should be able to relink to that media
    within Avid, but first lets make sure everything else is set up correctly.
    (all is assuming you are using a newer version of Avid with mxf media, not an older SD project running with OMFI media)
    Glenn
  • Chip Hess
    May 6, 2017 at 9:18 pm
    All is good.
    I had not changed Media Creation settings when I should have.
    Everything was there, just spread across two drives.
    Can anyone recommend an online resource explaining the uses/mechanics
    of relinking? I know there is a solid method for doing an uprez in online work,
    when cutting offline at a lower rez. Then connecting the edit decisions
    to original camera media.
    This is something I may need to tackle in the near future,
    and God knows the Avid manuals are not written for humans.
    Thanks very much.
  • Glenn Sakatch
    May 9, 2017 at 1:54 pm
    Scott Freeman has done quite a bit of stuff on relinking, although for some reason, I think most of his posts have disappeared from the cow. I’m sure he is blogging online somewhere.
    Glenn
  • Chip Hess
    May 9, 2017 at 6:55 pm
    Thanks Glenn!
    I Googled him and indeed found some good resources.
