Activity Forums Adobe After Effects Bringing in pre-rendered 3d objects and making them look clean… HELP!
  • Bringing in pre-rendered 3d objects and making them look clean… HELP!
    Posted by Jennifer on August 18, 2005 at 6:57 pm
    I am bringing in a prerendered object to my composition. Unfortunately, it looks jittery. How do I solve this problem. I seem to remember there was a way to bring it in deinterlaced and that cleaned up the mess, if you will. Does anyone have any suggestions?
    Thank you!
    Jennifer
    Jeff Dobrow replied 21 years, 1 month ago 2 Members · 1 Reply
  • Jeff Dobrow
    August 18, 2005 at 7:26 pm
    Determine the field order and framerate of your 3D render. (assuming it was rendered to fields).
    In AE, click on file -> Interpret Footage. Then set your Field dominance to match the footage as well as the frame rate.
