Activity › Forums › Apple Final Cut Pro Legacy › Bringing Anamorphic tag through to QT Player
Posted by Will Macneil on March 10, 2009 at 11:40 amSorry, one more question:
When we capture an anamorphic clip, with the anamorphic tag checked, why doesn’t quicktime player see it as an anamorphic file?
Is there a trick to get this to work?
W
Will Macneil replied 17 years, 6 months ago 3 Members · 4 Replies -
David Hartnett
March 10, 2009 at 12:39 pmUnfortunately, quicktime never seems to recognize anamorphic movies as anamorphic. There was a different way to fix this in previous versions, but with QT 7.6 you need to go to window>show movie properties (cmd J) Then choose Video Track>Visual Settings. From there you can change the scaled size to correct for an anamorphic clip. For PAL, this means unchecking “Preserve Aspect Ratio” and changing 720 to 1024, so your dimensions are 1024×576.
Editor – Speakeasy
http://www.speak.co.uk
FCPS & CS3
6 Intel Macs w/Kona 3/LH -
Rafael Amador
March 10, 2009 at 1:56 pmHi Will,
The solution that David suggest is OK for watching your movie in QT, but be very careful if you try to bring your movie to FC.
FC will interpret it as 1024×576 Square Pixels. Will make you render if you lie it in a PAL SD sequence.
I think that the problem is not QT, but the Apple codecs.
Before I used to have a BlackMagic. The DV Anamorphic I used to capture by FW shows up as BM DV.
It display perfectly Anamorphic as is recognized by FC as such. With the Apple Dv, no way.
rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Will Macneil
March 10, 2009 at 4:54 pmThanks, this was with ProRes (obviously an Apple codec.)
W
Will MacNeil
Film Editor
London
