Activity › Forums › Avid Media Composer › Bring MXF file from Managed media folder into bin in project window
  • Bring MXF file from Managed media folder into bin in project window
    Posted by Gary Madison on October 29, 2011 at 9:14 pm
    Hi
    I’m new to MC and cannot figure out how to bring an MXF file into a bin in an existing project bin.
    I did the delete function and removed the file but would now like to place that file back in it’s bin. It is residing in the Managed Media Folder on my Video drive, I just can’t figure out how to get the file from the Manged Media Folder into the bin.
    When I try to import the file I get an error message that says refer to documentation. I can’t find it in the documentation.
    I know it’s my error.
    Please help
    Only the Best to You
    gary
    Andrew Mckee replied 14 years, 11 months ago 2 Members · 1 Reply
  • Andrew Mckee
    October 29, 2011 at 9:34 pm
    Difficult to tell what you are getting at. In Avid, there is a Master Clip (which resides in the bin) and a Media File (which resides in the Avid Media files folder). Did you delete the master clip from the bin, but not the media file? If so, you can open up the media tool and search for master clips on the drive which the media file resides. This should bring up the master clip and you can then drag it into a bin.
    You cannot import the mxf files directly. Although you can import the mdb file that resides them and this will acutally import all the media files in that folder as master clips.
    Andrew McKee
    Editor/Colourist
    Avid Certified Instructor – MC5.5
    Apple Certified Trainer – FCP7
    Pixelwizard.net
