Activity › Forums › Apple Final Cut Pro Legacy › Bring Back Audio
Bring Back Audio
Posted by Jeremy Donaldson on March 17, 2010 at 10:41 pmIf I am editing in the timeline, and deleted the audio tracks from a clip. What is the shortcut, or easy way to bring back that audio?
Andy Mees replied 16 years, 6 months ago 4 Members · 4 Replies -
Walter Biscardi
March 17, 2010 at 11:18 pmPark the playhead over your clip on the timeline
Press “F” on the timeline for Match Frame.
This moves your original clip back into the Viewer with matched In / Out points.
Now you can easily re-edit the audio back into the timeline.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
Harvey Zinc
March 18, 2010 at 1:31 amHow do you bring audio only back? I pressed F located clip with in and out in the viewer but how does one then select audio only to place in the timeline under the video clip?
Harvey -
Walter Biscardi
March 18, 2010 at 1:36 amDeSelect the video track in the timeline and edit just the audio back into the timeline.
Andy Mees
March 18, 2010 at 2:28 amOr you might use the Replace Edit F11 function to replace both audio and video from source … as per Walter’s instructions, press F for Match Frame, then F11 for Replace Edit
