Activity Forums VEGAS Pro brightness/contrast filter issue in Vegas 11
  • brightness/contrast filter issue in Vegas 11
    Posted by Patty Loew on August 27, 2013 at 3:09 pm
    I’m having problems with the brightness/contrast filter in Vegas 11. I cannot see the changes I’m making in the preview window, but when I do a test render, the changes are there. Can anyone help?
    Edward Troxel replied 13 years ago 2 Members · 3 Replies
  • Edward Troxel
    August 27, 2013 at 7:40 pm
    Click the “Split Screen” button above the preview screen to turn off that option. Then look it up in the help file to see how useful it can really be.
    Edward Troxel
  • Patty Loew
    August 27, 2013 at 9:40 pm
    Edward, THAT WAS IT!!!! Thank you SO much. Such an easy fix. Hooray. Patty
  • Edward Troxel
    August 28, 2013 at 4:06 pm
    BTW, you’ll be better off if you don’t use the “brightness & contrast” filter. There are much better effects in Vegas to achieve the basic same task without just globally lightening or darkening every pixel in the frame.
    Edward Troxel
