Activity Forums Adobe Premiere Pro Brightness/Contract-Premier Pro 7.0
  • Brightness/Contract-Premier Pro 7.0
    Posted by Valerie Malla on April 16, 2009 at 5:18 am
    When working in Adobe Premiere Pro version 7.0 specifically, how do you brighten a video clip (whether in your bin or timeline?).
    I’m using the following method which isn’t working because I get stuck:
    1.) go to Project Bin – “Effects”
    2.) go to Video Effects
    3.) go to Adjust
    4.) go to Brightness & Contrast
    5.) click and drag the little plug-looking icon onto the clip in the timeline
    6.) Stuck – because nothing happens from here, no additional window or anything, just a red line at under the counterbar.
    Please help!!
    Eddie Lotter replied 17 years, 5 months ago 2 Members · 5 Replies
  • Eddie Lotter
    April 16, 2009 at 12:59 pm
    Once you have added an effect to a clip you can go to the Effect Controls Window to manipulate the parameters of the effect.
    Search the Help for “Effect Controls” and you will get the instructions you need.
    You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
  • Valerie Malla
    April 16, 2009 at 5:57 pm
    Thanks for responding Eddie. I am looking to adjust the Brightness however. The Effects Control is in the clip monitor and only has Motion and Opacity for visual effects.
    Again, this is for 7.0 version.
    Does anyone have any advice please?
  • Eddie Lotter
    April 16, 2009 at 6:31 pm
    All effects that have adjustable parameters will appear in the Effect Controls Window after you add them to a clip.
    If the “Brightness & Contrast” effect is not working for you then use the “Adjust” effect. Details are on page 269 of the Premiere Pro user guide.
    Cheers
    Eddie
  • Valerie Malla
    April 16, 2009 at 6:58 pm
    Thanks again Eddie, and this time it worked! ….I don’t know what I did differently, but it’s working now.
    Thanks again for your help, and quick responses!!
    Cheers, Valerie
  • Eddie Lotter
    April 16, 2009 at 8:58 pm
    You’re welcome. Happy editing. Happy editor
    Cheers
    Eddie
