Activity Forums Adobe After Effects Brightness problems.
  • Brightness problems.
    Posted by Giuliano Roca on September 10, 2009 at 4:46 am
    Hey guys,
    here is the thing, whenever i edit something in AE and tweak the color correction a bit and add brightness or dankness to it. In the inside AE preview window it will look fine and correct, but when i render it out into a wmv, or avi, it will look like washed out, like lost the colors like a lot more bright than what the preview window shows. Basically more bright.
    Help?
    PS: It also happens with premiere.
    Chris Brearley replied 17 years ago 2 Members · 1 Reply
  • Chris Brearley
    September 11, 2009 at 10:21 pm
    Probably because it being compressed like hell as a wmv. Export out as a .tif sequence, then you shouldn’t see any difference. Also your colour working space and the software you are using to play back your exports will make a difference to the appearence of the colours.
