Activity Forums Adobe After Effects Brightness flicker?
  • Brightness flicker?
    Posted by Leerik on March 7, 2006 at 9:11 pm
    I’m doing a fairly simple animation (mostly scaling and rotating) using only elements from an Illustrator PDF file in AE 6.5. It all looks fine (even in a RAM preview), but when I render it, the brightness of the frame flickers randomly and constantly. I’ve never really encountered this problem before. I rendered in several different codecs with no change. Anyone have any thoughts?
    Leerik replied 20 years, 6 months ago 2 Members · 2 Replies
  • Chuckwagon524
    March 7, 2006 at 9:30 pm
    Sounds to me you might have field domionance problem. It’s hard to say without seeing it but I’ve run into this before when either my field wasn’t set right and/or my artwork had really fine lines. There are many ways to fix this that largely depend on what you are outputting to.
  • Leerik
    March 7, 2006 at 9:50 pm
    Thanks for the reply, Chuck. I’m outputting to Quicktime (to post on the web). There aren’t really a lot of fine lines in the piece, I wouldn’t say. This is probably a stupid question, but would field dominance be an issue even if there aren’t any video clips involved in the piece?
