Activity › Forums › Maxon Cinema 4D › Bright white material
  • Bright white material
    Posted by Andrew Watson on October 29, 2019 at 6:10 pm
    Hi, I’m using C4D and I have a scene, in it, a spotlight shines on a plane (and other objects). I need the plane to be 100% white (#ffffff) all the time except when something passes in front of it creating a shadow from the spotlight. Like if I set it as a matte object, but I need it to be in shadow if there is something in front of it.
    There are other things in the scene so I can’t just ramp up the spotlight, nor can I use something like self illumination for the material because then there won’t be a shadow.
    Does anyone know a way that I can get my material to bright white except when in shadow?
    It help to note, I’m using Global Illumination.
    Any help appreciated!
    Andrew Watson replied 6 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    October 29, 2019 at 6:42 pm
    In the Compositing tag don’t use Matte Object use Compositing Background which makes the object act self illuminated but still receive shadows. The plane (in your example) has to have a material on it which is where you set it to white.
  • Andrew Watson
    October 29, 2019 at 6:52 pm
    Holly poop balls! That is absolutely it!!!!
    Thank you very much!!!!
