Activity › Forums › Adobe After Effects › Bright Sign Video Wall
  • Bright Sign Video Wall
    Posted by Erik Franzen on January 8, 2013 at 6:39 pm
    I am working with a 3 Monitor Video wall. i have the Video all made but need to cut up the video into 3 small sections to Sync to all the players. I am new to AE and I have followed some Comp stuff but I don’t know how to render it out to the three files that I need. any help would be great Thanks.
    Walter Soyka replied 13 years, 8 months ago 4 Members · 4 Replies
  • Ridley Walker
    January 8, 2013 at 7:00 pm
    If I understand you correctly, one approach is the following.
    Create a Master Composition which is 3 times wider than the size you need for the individual rendered screens.
    Create Left, Middle and Right Comps at the size you need to render for each screen.
    Place the Master in each of the above Comps by dragging the Master from the Project pane into the Timeline, and position accordingly. Hold down the Shift Key as you move the Master in the Left and Right Comps to snap it to the edges of the screen.
    Left has the left edge of the Master as its left edge.
    Right has the right edge of the Master as its right edge.
    Middle has the Master placed in it with no position adjustment.
    Render Left, Middle and Right Comps.
  • Erik Franzen
    January 8, 2013 at 9:57 pm
    I got it to work I was trying to drop the Smaller Comp onto the master instead of the other way around. I also then made 3 more comps and did a -90 degree rotation as the 3 screens are portrait mode. I render the 3 rotated comps and everything is happy. thanks
  • Matthew Keane
    January 9, 2013 at 11:17 am
    Another way is to render out a large uncompressed master clip (e.g. Quicktime Prores or Animation) and then use Adobe Media Encoder to crop and export the chunks. If for some reason you need to tweak the compression settings, you won’t need to rerender your sequence.
    Matthew Keane
    Freelancer based in Paris, France
    – Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation.
  • Walter Soyka
    January 9, 2013 at 8:13 pm
    [Matthew Keane] “Another way is to render out a large uncompressed master clip (e.g. Quicktime Prores or Animation) and then use Adobe Media Encoder to crop and export the chunks.”
    Image sequences would be a good choice, too.
    I use image sequences and proxies very heavily in my large-raster Ae workflows.
    Walter Soyka
