Activity › Forums › Adobe Photoshop › Bridge renaming errors…bamboozled
  • Bridge renaming errors…bamboozled
    Posted by Andy Scofield on September 27, 2013 at 2:28 pm
    Hi gang,
    New member here, hoping to tap the hive mind for a solution to/explanation of an error I get when renaming files in bridge. I’ve scoured the Adobe site, CC forums and Google, but can’t find anyone else with this exact problem, let alone a solution.
    I’m renaming a job lot of JPGs, after cropping and doing absolutely nothing to the metadata I use a photoshop action to title them in a templated format : XBOXEP_$_EP
    The ens result I’m trying to achieve is a filename like this: XBOXEP_TITLE_EP01
    Bridge is perfectly capable of swapping the “$” for any short text I want, but trying to use Sequence Number causes problems.
    Bridge puts the sequence number AFTER the file extension, creating this: XBOXEP_TITLE_EP.jpg01
    I’ve tried to use the sequence number without the first “$” rename, and the same error still occurs
    While it’s a simple enough task to add in the numbers myself, it’s insanely annoying that I can’t figure out the glitch.
    I’m on Mac OSX, have Bridge optimised for this and haven’t had any other issues with Batch Rename.
    Any ideas/solutions?
    Jonathan Ziegler replied 12 years, 12 months ago 2 Members · 3 Replies
  • Jonathan Ziegler
    September 28, 2013 at 3:42 pm
    Don’t you have to add .JPG to the end in the naming format? In other words, instead of “XBOXEP_$_EP” shouldn’t it be “XBOXEP_$_EP.JPG”?
    Just a thought. Also, can’t you specify in the script where the numbers go? Can you post the script?
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Andy Scofield
    September 30, 2013 at 8:57 am
    Jonathan,
    Thanks for the response.
    I’ve tried that approach, Bridge still adds the file extension on, so I get “XBOXEP_$_EP.JPG.JPG”
    In terms of scripts, I didn’t write one myself, I used the pop-up “wizard” in Bridge itself.
  • Jonathan Ziegler
    September 30, 2013 at 4:23 pm
    Hmmm, well I don’t know how to make that work, but maybe you can try the File Sequencer. https://www.johnnarun.com/file_sequencer/ – it’s for Mac only, but there are similar apps for Win.
    Jonathan Ziegler
    520-360-8293
