Activity › Forums › Apple Final Cut Pro Legacy › breaking up markers
  • breaking up markers
    Posted by Brett Juchniewicz on June 26, 2008 at 4:51 pm
    I have some continuous footage of some basketball, but I want to just take out a few bits of footage from it. How do I isolate those shots by using markers? Do I set up separate in and out points or should I just do that with the raw footage?
    Kris A. wotipka replied 18 years, 3 months ago 3 Members · 2 Replies
  • Richard Harrington
    June 27, 2008 at 3:28 pm
    Just use the markers and set in and out points.
    Thn File Export
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Kris A. wotipka
    July 1, 2008 at 3:45 pm
    I know that FCP can export between IN and OUT points if they are set. Made that mistake numerous times. I don’t think that you can set markers of a given duration and export multiple clips based on marker location. You can use the markers and set a duration and then come back and match the IN and OUT edit points with the Markers In and Out points and export your clips one at a time. There may be an automated way to do this but I do not know.
    kw
    kris@wotipka.com
    Image maker
