Activity Forums Maxon Cinema 4D breaking up an object and rotating it…..
  • breaking up an object and rotating it…..
    Posted by Craig Whitaker on March 27, 2011 at 1:01 am
    Hey everyone,
    Trying to setup a short shot where an object is already broken into a bunch of pieces, swirling around a “tornado” towards to the ground where the pieces will then assemble the original, assembled geometry. Is there a way to do this without having to go into TP?
    Thank you,
    Craig
    Craig Whitaker
    MFA Candidate
    New York University
    http://www.craigwhitaker.net
    Adam Trachtenberg replied 15 years, 5 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 27, 2011 at 4:20 am
    This is a bit complex, but probably not as bad as TP. 😉
    1801_tornadotoobject.c4d.zip
    Probably more complex than it needs to be actually, but here’s what’s going on:
    I have a matrix object with about the number of particles as the final object has polygons (a few more);
    I have another matrix object that’s cloned onto the torus;
    The second matrix object has an animated inheritance effector that makes the particles go from the torus object to the first matrix object. Along the way it passes through a twist deformer, which forms the tornado;
    Finally I have the torus object modified by a polyfx object, which has an inheritance effector assigned that causes the polygons to follow the second matrix object.
    Also some random effectors to, uh, add randomness.
    As I think about it now I probably could have used just one matrix object with a plane effector and random effectors to make the tornado, and then inherited that.
  • Craig Whitaker
    March 28, 2011 at 12:07 pm
    Hey Adam,
    Thank you so much for taking the time to do this. I see that you’re using a primitive torus, if I’m using editable poly for this (let’s say a cube sliced up (Thrausi’d) into 100 pieces, is the process still the same?
    Thank you,
    Craig
    Craig Whitaker
    MFA Candidate
    New York University
  • Adam Trachtenberg
    March 28, 2011 at 2:38 pm
    If the object has already been split up you would put the pieces into a fracture object instead of using the polyfx object.
