Activity Forums Adobe After Effects “Breaking Apart” Compositions (saving workflow steps)
  • “Breaking Apart” Compositions (saving workflow steps)
    Posted by Alex Volkov on August 6, 2010 at 12:55 pm
    Hi again
    (I hope it’s ok I create another topic right after my previous one. Those are important issues for me.)
    But here it goes:
    As a Flash veteran, I like to think of some of the features in After Effects, as if they were Flash’s features. For instance; “Pre-Compose” (making an object or animation into a specific composition), I like to think of as “Convert into Symbol” in Flash.
    In Flash you can break apart symbols (Ctrl+B), destroying the symbol, replacing it with the actual content. Unless the symbol contains a tween/shape animation inside. But.. if you had symbol 3 inside symbol 2, inside symbol 1, and you Broke apart Symbol 1 twice, you would end up having Symbol 3.
    I was wondering if there was a similar feature in After Effects with Compositions? In stead of going inside a specific Composition, Cutting the Layers, going one step back (out of the Composition), and Pasting the Layers..
    Is it possible? If yes – how?
    Thank you for reading this
    P.S. I am still in the learning phase of After Effects, so perhaps I have mistaken some of the current features.
    Dave Johnson replied 16 years ago 2 Members · 1 Reply
  • Dave Johnson
    August 6, 2010 at 1:34 pm
    Unless there’s a new feature I’m unaware of or have forgotten something, a set of AE layers that has been pre-composed can’t be un-precomposed except via undo, which wouldn’t accomplish what it sounds like you want. You can easily duplicate layers before pre-composing them or copy them from comp to comp as many times as you want, but those are the only ways I can think of to get what you want.
