Activity Forums Maxon Cinema 4D Breaking an object into segments without seams
  • Breaking an object into segments without seams
    Posted by Ryan Kehn on June 22, 2010 at 4:12 am
    Hey Everybody,
    I’m trying to build what I’ve come to find out is referred to as a “ball robot”.
    anyway, I’ve been able to break up my sphere in the sections that I want, however, when I render i’m getting seams where the section breaks are. I’m really trying to go for the look that the sphere is completely seamless, and then animates/transforms/opens. I was able to find an example of what I’m after in the link below.
    I’ve tried disonnecting/splitting the polygons out into new objects and adding hypernurbs with some weighting, but no dice.
    Any suggestions would be greatly appreciated!
    Ryan
    Adam Trachtenberg replied 16 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 22, 2010 at 2:57 pm
    I would suggest you use two spheres: one whole and one cut up. Then keyframe the visibility of the whole sphere off and the cut up sphere on at the frame where the split is to occur.
