Activity Forums Adobe After Effects Break in image sequence
  • Break in image sequence
    Posted by Lisa Simonson on June 24, 2010 at 1:25 am
    Argh!!
    There is an extra 0 in the numbers of second render to tiff sequence ( computer crashed so i had to start over )I can open all the images separately in photoshop and some show up in my AE project but other than that, most frames read only as color bars in the comp.
    Double argh!
    Does anyone know a way to fix this?
    Lisa Simonson replied 16 years, 2 months ago 2 Members · 3 Replies
  • Lisa Simonson
    June 24, 2010 at 1:28 am
    Do I have to take out the extra “0” in all 1300 frames?
  • Joseph Pole
    June 28, 2010 at 7:35 am
    It is fairly straightforward to do a batch rename and remove the extra zeros if you have adobe bridge (or any other app with batch rename)
    in bridge navigate to your render, select the files with the superfluous zeros, then navigate to Tools/Batch Rename. That’ll open up a window with a very clear batch rename interface.
    *you might want to copy a portion of your render into another directory and do a test first.
    http://www.josephpole.com
  • Lisa Simonson
    June 30, 2010 at 8:56 pm
    Thanks for the seriously helpful info! Will definitely use in the future.
    Manually deleted all the extra zeros before I got this tip. Ikes!
