Activity Forums Maxon Cinema 4D Break Down an Instance Object
  • Break Down an Instance Object
    Posted by David Biederbeck on August 12, 2012 at 1:36 am
    I’m trying to break down a complex model to a single object. When I hit “Current State To Object” I lose all the instnace objects.
    So I tried to break them down into their own individual poly objects, and I can’t seem to get it to work. Any ideas?
    David Biederbeck replied 14 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 12, 2012 at 4:33 am
    First select all your instance objects and make sure “render instance” is unchecked. Then make them editable. Then select all of your objects and run “connect” or “connect & delete”.
  • David Biederbeck
    August 12, 2012 at 4:34 am
    Nice. I had put it to bed after a long day. I’ll try it on Monday. Thx!
