Activity › Forums › Adobe After Effects Expressions › Break a time remap expression
  • Break a time remap expression
    Posted by Milos Milunovic on May 22, 2015 at 11:06 am
    Hi people, another rookie in expressions.
    here is my problem:
    I have a composition with time remap and a expression:
    state=comp(“comp_1”).layer(“character”).effect(“outfit”)(“ADBE Slider Control-0001”);
    framesToTime(state);
    Null with a slider that is controlling a time remap.
    I wont to break expression with a checkbox and be able to controll the compositions frame number with another null and a slider.
    My humble opinion is to use if/else command.
    I managed to do similarly with this exspression:
    effect(“default”)(“Slider”)
    if (effect(“dafault_character_on/off”)(“Checkbox”).value)
    {effect(“default”)(“Slider”)
    }else
    value
    in general I need to break a time remap expression (that is controll by a slider) with checkbox and use another slider to control the same composition.
    Thanks in advance.
    Dan Ebberts
    replied 11 years, 4 months ago
    2 Members · 5 Replies
  • Dan Ebberts
    May 22, 2015 at 5:03 pm
    I haven’t tested it, but I guess it would be like this:
    if (effect("dafault_character_on/off")("Checkbox").value){
    state=comp("comp_1").layer("character").effect("outfit")("ADBE Slider Control-0001");
    }else{
    state=comp("comp_1").layer("other null").effect("other slider")("ADBE Slider Control-0001");
    Dan
  • Milos Milunovic
    May 22, 2015 at 6:56 pm
    Dan, thank You for replay.
    I will try it.
    works perfectly!
    thanks
    Dan,
    is it possible to pick whip both way two sliders? if I type a number 12 in one the other change to 12 and the other way if I type in second slider some value the first slider change to that value.
    Is there an expression for that?
    I try to pickwhip-it and I get some funky results.
    Thanks.
  • Milos Milunovic
    May 25, 2015 at 12:43 pm
    Works perfectly.
    Thanks again.
  • Milos Milunovic
    May 25, 2015 at 2:47 pm
    Dan,
    Thanks.
  • Dan Ebberts
    May 25, 2015 at 3:53 pm
    Setting up two expressions so that each depends on the other for its result will give you unpredictable results. Don’t do it.
    Dan
