breadcrumb problem
I have a tricky problem.. I am using breadcrumb trail to show path to my pages. In order to run breadcrumb i have created folders for each page then categorized and sub-categorized each folders. certain of subcategories comes under 2 or 3 categories. Here i have a problem. In order to show true path every time, I need to add same subcategory under 2 or 3 category separately. Only problem with this is, it increases work tremendously.
let me explain you in detail with links..
Here is a page with Subcategory ” Qaymat Se Qaymat Tak” under category ” Aamir Khan”
https://www.reedhee.com/hindi%20movies/aamir%20khan/qaymat%20se%20qaymat%20tak/index.php
Here is same sub-category ” Qaymat Se Qaymat Tak” under different category ” Juhi Chawla”
https://www.reedhee.com/hindi%20movies/juhi%20chawla/Qayamt%20se%20Qaymat%20tak/index.php
in both of this link I need to add same page separately for same sub-category(Qayamat Se Qaymat Tak), because both have different category.
does anybody have any idea how to add sub-category page only once and it will work for both category…
thanks
