Activity Forums Maxon Cinema 4D Branching splines and smooth intersections
  • Branching splines and smooth intersections
    Posted by Stu Pond on January 9, 2007 at 10:04 am
    I have a job where I need to create a simple branching structure like veins or tree roots that grow. I can do this with splines, but you can always tell where the intersections are.
    Anyone know of a quicker way of creating this effect so it looks seamless and organic? I am using R10 XL bundle and have MoGraph.
    Cheers,
    stigWeard
    Stu Pond replied 19 years, 8 months ago 2 Members · 2 Replies
  • Mylenium
    January 9, 2007 at 10:34 am
    I suggest that you find a plugin called Chamfer maker. It’s hosted on a Russian website and you need to register, but it’s free. You can then combine your branches and trunk using booleans aand throw it inside said object. It can automatically round/ blend edges based on a angel and creates perfect geometry that then can be smoothed further in a HyperNURBS. Another option might be fusionThing, a commercial plugin that will also blend different separate objects.
    Mylenium
    [Pour Myl
  • Stu Pond
    January 9, 2007 at 12:26 pm
    Thanks Mylenium!
    I’ve downloaded it but as I’m on my MacBook at the moment I’ll have to wait to try it as it doesn’t work with UB versions of R10.
    stigWeard
