Activity Forums Maxon Cinema 4D BP UV point coordinates
  • BP UV point coordinates
    Posted by Bart Winckers on April 12, 2013 at 1:13 pm
    Hello,
    I need to make accurate custom UV maps. Is it possible to manually enter the coordinates for an UV point, so that I can place it on an exact position? (For instance like you can do with points in the coordinates tab in C4D).
    If not, does anyone know an UV editor that has those capabilities? Or another solution that does not rely on visual reference.
    Greetings,
    Bart
    Bart Winckers replied 13 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 12, 2013 at 3:24 pm
    It’s possible to do in Cinema, but pretty awkward. Basically you have to open the structure manager and set the mode to UVW. Then you’ll have to select a UVW point and move it while looking at the structure manager so you can tell which point you’re dealing with. Once you see which values are changing you can set them manually.
  • Bart Winckers
    April 15, 2013 at 2:15 pm
    Thanks! Works for me.
