Activity › Forums › Sony Cameras › BP-U60 Battery Charging
  • BP-U60 Battery Charging
    Posted by Todd Sandler on January 23, 2009 at 2:53 am
    Is it bad to always charge a BP-U60 lithium ion battery (for an EX1) if only 25% has been used?? Should we wait until its fairly drained (75%-85%) before charging??
    Thanks for your help
    Todd
    Olof Ekbergh replied 17 years, 8 months ago 3 Members · 2 Replies
  • Michael Palmer
    January 23, 2009 at 3:06 am
    Lithium ion batteries are one of the best energy-to-weight ratios sources of power with no memory effect, so go ahead and recharge them when you need to.
    Good Luck
    Michael Palmer
  • Olof Ekbergh
    January 23, 2009 at 8:32 pm
    I now there is not supposed to be a memory problem with these batteries.
    But I still think LION batts will loose capacity over time if you only run them down 25% or so for years.
    So I run them down all the way once a month or so. This really applies to laptops.
    I got 2 of the longer running batts for the cam, and use the orig small batt for the HD recorder on the EX3, and that uses only 25% of the power in 4 hrs of recording, so it never really drains all the way.
    I actually make a point of running that battery in cam when not using HD recorder, just to drain all the way down.
    Maybe I am being over cautious but it is not that hard to run batts all the way down once a month. I mark my batts with the last drain date, so I can keep track.
    Olof Ekbergh
