Activity › Forums › Maxon Cinema 4D › BP EV UV mapping question
  • BP EV UV mapping question
    Posted by Chad Demoss on April 25, 2016 at 5:36 pm
    I’m new to this so I watched a good tutorial but I’m doing something wrong. I’m using box projection it but its not unravelling it all the way.
    Here’s 2 screengrabs. you can see that when I paint on the one face it shows up on two faces. I messed around with unravel but I’m slicing it incorrectly or this isn’t the right tool.
    Brian Jones replied 10 years, 5 months ago 2 Members · 2 Replies
  • Chad Demoss
    April 25, 2016 at 7:27 pm
    I was able to break this all apart by selecting areas and making 3 separate uv maps. This is a real basic model so it isn’t a problem but i’m not sure if this is how other people would do this or if there is an easier way. here is a screen grab of what i did.
  • Brian Jones
    April 25, 2016 at 7:40 pm
    not that I BP much but with Box projection that’s what I would expect. It is UVW that gives individual control over every poly
