  • Posted by Steve Robinsons on March 18, 2021 at 9:39 am
    var posx = transform.xPosition;
    var posy = transform.yPosition;
    var rect = thisComp.layer("BG Box").content("Rectangle 1").content("Path 1").scale;
    var x= ease(posx,rect[0]/-2+20,rect[0]/2-20,10,100);
    var y= ease(posy,rect[1]/-2+20,rect[1]/2-20,100,10);
    [x,y]
    This time, I want to establish the limit in this white box regardless of its scale. I mean, if the scale changes the limit changes too.
    Here my wrong attempt:
    Thank you!!
    Yoan Boisjoli replied 5 years, 5 months ago 2 Members · 1 Reply
  • Yoan Boisjoli
    April 1, 2021 at 2:37 am
    Hi Steve, so you would like to have the pink square contained in the white box no matter how big the white box gets?
    I think you could use the clamp() method.
    Here’s a quick tutorial on it: https://youtu.be/MITA3ygqvQY?t=314
    Basically in your case you could use sourceRectAtTime() to establish the limits of the Y and X position of the pink square.
